This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Solved Author is not shown... (but recognised).
5 years 7 months ago #217178 by Granpa
I just installed Kunena on an up-to-date Joomla website.
I entered my first Topic.
On my profile accompanying the topic, it says that I am the topic author (correctly).
BUT, in the topic itself it just says: "<Title> was created by                      "  ... and nothing more...
I have not made many alterations from the default configuration for Kunena/Crypsis.
But maybe I just inadvertantly set something wrong, but I fail to see what that could be...
Any suggestions as to what I should check?
5 years 7 months ago #217200 by xillibit
Can-you put here please your Kunena report configuration ?
5 years 6 months ago #217241 by gboy
I seem to be having the same problem.
Here is my Kunena report.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 512M
Joomla default template details : shaper_helix3 | author: JoomShaper.com | version: 2.5.8 | creationdate: Jan 2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.2.4 | creationdate: 2021-04-04
Kunena template params:
Kunena version detailed: Kunena 5.2.4 | 2021-04-04 [ Koios ]
Third-party components: CommunityBuilder 2.5.0+build.2021.03.11.22.09.58.2db0d260e
Plugins: None
Thanks I appreciate all the help you can give.
5 years 6 months ago #217252 by rich
You have chosen in Kunena "Display User Name = No". This option shows the real name instead of username.
If you want this, you must set in the Community Builder configuration (tab General) the name format to Name Only (or "Username ('Name)" if you want to see both).
5 years 6 months ago - 5 years 6 months ago #217256 by gboy
Thank you Rich.
That fixed my issue, although I see now that I can only use "name" to have it appear in the forum.
firstname + Last intial or vise versa don't seem to render.
In either case I guess I will have to do a workaround to get the results I will need.
Thanks again.
Last edit: 5 years 6 months ago by gboy.
5 years 6 months ago #217257 by rich
You don't need a workaround. Add a second field for the registration (see image). Now you have fields for:
First Name
Last Name
Username
Now you see with the option "Name Format = Name Only" the first and last name.
Time to create page: 0.163 seconds
