Question K 1.7.1 Polish language frontend: pl-pL should be pl-PL
14 years 8 months ago #118914 by Pedrinho
Hey, I will join this topic to avoid creating new one.
I had the same problem as here and solved it thanks to djeeke advice.
Now I have both back and front end translated except Kunena front tabs (Index,Recent Topics,No Replies...). My Joomla is set to Polish both back and front and can't find where is the catch with these tabs.
Any advices?
Many Thanks
14 years 8 months ago #118916 by Pedrinho
ok, I have discovered the obvious now :). The trick is to change manually names in Joomla Menu's section :P
Time to create page: 0.101 seconds
