- Thank you received: 2
Question K 1.7.1 Polish language frontend: pl-pL should be pl-PL
I'm brand new to this, just installed a Joomla, just installed kunena as it seems a great tool...
I would need the frontend to be in Polish, there seems to be a Polish translation but only for the frontend...
When I try to install the frontend language I get the error "install_4f1068b458723/pl-pL.com_kunena.tpl_default.ini" does not exist...
Am I right in thinking this will only work once the backend is translated ?
If I read correctly installing a previous version of Kunena (1.71 now) is a security risk so this is not an option either...
That page states :sozzled wrote: See K 1.7 Language Support
Thanks sozzled...If there is only the "admin" or "site" language available
Can you install only the "admin" kit without the "site" kit or vice versa? Yes you can but you should know that the administrator (backend) or frontend site - whichever one is missing - will not be "user-friendly". The language will be in English.
So it should be possible, only I am getting the above error message...
any hints anyone ?
Check if the file pl-pL.com_kunena.tpl_default.ini exist in your language package
After the K 1.7.1 kit was released, the Polish translation was updated: see Language pack collection for K 1.7.1 . I hope this helps.
xillibit, thanks for reminding me to re-read the XML file and compare the filenames in the zip ...
Two of the files are listed as pl-pL instead of pl-PL and as we know these systems are cery case sensitive... Corrected in the XML file and installed like a charm...
Do I report these typo's to someone (and if yes, how ?)
Thanks for the support guys
