Question [Problem] Invalid Token problem related to Kunena Component
17 years 5 months ago #18071 by Sovietaced
Dear Jason Parraga,
Thank you for your reply.
I checked your website and registered an account.
When i login to your website, it redirect to the com_kunena component.
The system updated session for the user but this component is not.
I still try to login it continue and i saw this noticle.
This issue is from the com_kunena component or your configuration.
I think you should post this issue to from of com_kunena component for more detail.
Sincerely,
Cao Hau
JoomlArt.com Customer Service.
www.joomlart.com
_____________________________________________________________________________________
I recieved this message from Cao @ Joomlart. I had been trying to get rid of the invalid token screen when logging in. I have searched every single thread about it and still have the problem. Apparently it is a problem with kunena and the user session. Thanks in advance.
17 years 5 months ago - 17 years 5 months ago #18077 by JBHawaii
Have you enabled the system cache plugin in joomla? this has been know to cause the invalid token issue with login.
If so try disabling it. and see if that solves it.
Mahalo,
JBHawaii
Last edit: 17 years 5 months ago by JBHawaii.
17 years 5 months ago #18079 by Sovietaced
I have disabled it in the past and the problem persisted. I changed the session lifetime of joomla to 30 minutes so that it is the same as kunena. This was both sessions will expire at the same time. I also turned off the cache, to be safe. I'll probably reply here in a day or so with the progress.
17 years 5 months ago #18080 by JBHawaii
In order for you check it remember to clear you cookies & cache, also clear any cache in the joomla back-end.
Hope everything works out for you :)
Mahalo,
JBHawaii
17 years 5 months ago #18257 by Sovietaced
still getting the error.. what do I do kunena?
17 years 5 months ago - 17 years 5 months ago #18260 by sozzled
G'day, Sovietaced :)
A couple of days ago you were advised to upgrade to from K 1.0.9 to K 1.0.10 ( #18006 ). Have you done that?
Your website - which I think looks excellent - uses a Kunena template (default_gray) which the developers have said causes problems. The only two templates that the Kunena developers have said should work, in 95% of instances, are default and default_ex. This doesn't mean that default_gray won't work, but it may be the cause of many unexpected "things".
In addition to the Kunena template, you're also using a JoomlArt template. I realise (from the first posting in this topic) that their developers will stand by their product - and it does no good getting into a finger-pointing exercise as to who or what is "responsible" - but do you experience your current (invalid token) problems using a "standard" Joomla template like JA_Purity or rhuk_milkyway? If you don't have those problems then maybe it's the JoomlArt template? :dry:
Lastly, what version of Joomla are you running all these things with? You've asked for help and we'll do our best. Cheers ;)
Last edit: 17 years 5 months ago by sozzled.
