Question Unread posts does not work in listcat view
17 years 5 months ago #17499 by mibert
Hi there,
I have upgraded to CB1.2.1 and Kunena 1.0.10 with Joomla 1.0.15.
When looking at the Category view of the forum, the forum shows many unread items, even I am sure that I have read them already.
I tried the function "Mark all as read" but not change.
Any advise would be most welcome.
Best regards
Michael
17 years 5 months ago #17572 by mibert
Any idea, what could be the problem??
Thanks in advance and best regards
Michael
17 years 5 months ago - 17 years 5 months ago #17607 by sozzled
Thank you for providing the information that you are using J! 1.0.15. This may also be the cause of the couple of other problems that you're having with Kunena - in particular those functions that depend on Javascript.
J! 1.0's javascript library is very different to J! 1.5's (even though J! 1.5 needs to be run in "legacy mode" in order to support Kunena). We have already seen other examples (see Couple issues after upgrade and Forum jump not working correctly ) where the only common determinant seems to be J! 1.0.x. There seems to be a lot of circumstantial evidence pointing to J! 1.0.x as the culprit, the cause behind many of these Javascript-related errors - too much to ignore, in my opinion.
While it's impossible to conclude, with certainty, that Joomla!1.0.x is incompatible with K 1.0.10, there seems to be some anecdotal basis for saying that it might be.
Have you considered the possibility of transporting your site to a J! 1.5.10 platform? J! 1.5.10 might solve this problem, your IE problem, your quick reply problem and many other problems you're currently having.
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #17642 by mibert
Hi Sozzled,
thanks for your advise. I am planing to update my site to J1.5 within a few month but if you had a look at it, you will understand that it will be a major job.
My site is huge and utilizes many components and modules.
Best regards
17 years 5 months ago #17771 by sozzled
mibert wrote
I am planning to update my site to J! 1.5 within a few months but ... you will understand that it will be a major job. My site is huge and utilizes many components and modules.
As the ancient Chinese philosopher Lao Tzu is reputed to have said, "The journey of a thousand miles begins with one step."
Although we do not have conclusive evidence that Joomla 1.0.15 is responsible for a number of functionality issues with Kunena 1.0.10, it's reasonable to conclude that the more components you add into the mix increases the complexity in managing your website.
There's saying we have in English: "KISS" - Keep It Sweet & Simple" (or "Keep It Simple, Stupid", if you prefer).
In the meantime, if your website was working with Kunena 1.0.9, you might have to revert to that version until you're ready to move ahead with Joomla 1.5. Be advised, though, there's little-to-no support available for J! 1.0. The longer you continue to use it, the longer you're on your own with the problems and restrictions it imposes. Make that "first step" ... ;)
17 years 5 months ago #17981 by Matias
FYI: Fxstein runs his own site on Joomla 1.0 + CB and has large, active forum.
