- Thank you received: 3
Question karma problem
- grumblemarc
- Elite Member
- Still making trouble
What is your Joomla version?
Kunena version?
SQL?
PHP?
Was this a recent problem? As in did it work before but not now?
- heliolopes
- Junior Member
Im using Joomla version 1.5.10
Jomsocial 1.1.145
com_kunena_v1.0.9_b1231_2009-04-03
phpMyAdmin - 2.11.6
# MySQL client version: 5.0.22
# Used PHP extensions: mysqli
Regards
Helio
- heliolopes
- Junior Member
So, still no idea about what might be happening with the karma system, right?!
Regards,
Helio
Dear grumblemarc,
I will copy paste the web address and send it to you by PM for you to see what Im speaking about.
Regards,
Helio
Hi Helio,
PM to me??
Regards
I haven't contributed to this discussion because I don't really understand the technical matters involved in processing "karma", however there are a couple of factors that may be involved:
- What Kunena template are you using? As you may have read elsewhere, K 1.0.10 breaks "old" templates; if you're using a template other than default_ex (or default) you will have problems. The image shown in your original question looks like a CSS problem.
- Are you using a third-party extension like Community Builder? K 1.0.10 needs CB 1.2.1 if you are using that product. CB 1.2 causes problems with Kunena Javascript calls.
When you're diagnosing these kinds of errors, always go back to the standard settings that came with the product and verify they work, independently of everything else, and then start changing things one by one until you find what causes things to come apart.
Good luck
- heliolopes
- Junior Member
So maybe this problem and also the conflict with the com_onlineusers.php that nobody answer me is related to the template as well.
Im using a very nice template called numinu_ex.
I have tried to attached it but its 451 Kb
