Question *SOLVED* How-to: CSS Speech Bubbles & Topmenu links into Profilebox ..
17 years 6 months ago - 17 years 6 months ago #14867 by sozzled
I spent about 2½ hours unsuccessfully trying to adapt the solution to the Kunena default_ex template. Although Eddy's solution works for him (because his template has contrasting off-white background and the white "bubble" renders nicely against it) it doesn't work successfully with default_ex template that displays messages against a pure white background.
I've also experimented, unsuccessfully, by trying to use a contrasting background, like this:
div.msgtext { position: relative; background-color: #f0f0f0; padding: 25px; } span.arrow{ width: 0; height: 0; line-height: 0; border-left: 30px solid #f0f0f0; border-bottom: 15px solid white; position: absolute; top: 20px; left: -30px; }
I took Eddy's template and used it on my test site and everything works fine. Evidently, there's another CSS tag that's used by Eddy's template that's assisting his technique, but I can't find what it might be. Any ideas?
Last edit: 17 years 6 months ago by sozzled.
17 years 6 months ago #14880 by Lintzy
johnnydement wrote:
yOu could work a nifty template from this getting rid of the grey box around the speech bubble ;)
Something like this?
17 years 6 months ago #14889 by johnnydement
Well. depends, is that site having a black background? ;)
I would also "transparentize" user profile :P
17 years 6 months ago - 17 years 6 months ago #14891 by Lintzy
hehe, yes it was made with a little bit CSS. Changed the background, of course you can take every color you like for that.
It was just a fast example.
Not this side has a black background, but the messagebox. What was grey before.
Last edit: 17 years 6 months ago by Lintzy.
17 years 6 months ago #14892 by sozzled
Apart from the one-line change to message.php (see www.kunena.com/forum?func=view&catid=90&id=14366#14420 ) what CSS changes have to be made to the Kunena default_ex template to display a grey "talk bubble" against a white background?
17 years 6 months ago #14893 by Lintzy
You mean, the bubble itself should be grey and the background around the bubble white?
