Question White page and installation failure.
16 years 11 months ago #14963 by Matias
See your PM.
16 years 11 months ago #15621 by iancaz
I'm having the same issue as this on my dev server. Any "common" solution to this?
I'm running:
PHP Version 5.2.6
MySql version 5.0.67
I've got error reporting set to max & I get nothing but a blank page. This was an upgrade from Fireboard 1.0.5 to Kuena v1.0.9.
Let me know if you need more info.
16 years 11 months ago #15626 by iancaz
Okay, after seeing a post here I decided to turn off community builder integration & this "fixed" my problem. My next step is to try upgrading those components.
16 years 11 months ago #15634 by Matias
If integration fixed your problems, you probably run out of allowed memory in PHP. It's not enough to turn error reporting to max, you have to either read error log from Apache or turn on error reporting into screen from PHP.
16 years 11 months ago #15714 by naveen_rang
I have the same error and i have reported under the post 'Screen Blanks White while attempting Install'
16 years 11 months ago #15735 by naveen_rang
Ok. I had the same problem and now I have installed Kunena 1.5.
First i unzipped the downloaded file to a local directory on my computer, then i created a folder called kunena in the tmp folder of Joomla on the server. I uploaded all the unzipped files on my local computer to the tmp/kunena folder.
I ran Install from a Directory and pointed the path to the tmp/kunena folder.
Installation was successful. I guess it is because of the 30 second timeout. As some of us have our sites on shared hostings, it may or may not be possible to get the hosting company to increase the timeout period.
Give this a shot and i am sure it would work.
Naveen
Time to create page: 0.287 seconds
