Question White page and installation failure.
17 years 6 months ago #15626 by iancaz
Okay, after seeing a post here I decided to turn off community builder integration & this "fixed" my problem. My next step is to try upgrading those components.
17 years 6 months ago #15634 by Matias
If integration fixed your problems, you probably run out of allowed memory in PHP. It's not enough to turn error reporting to max, you have to either read error log from Apache or turn on error reporting into screen from PHP.
17 years 6 months ago #15714 by naveen_rang
I have the same error and i have reported under the post 'Screen Blanks White while attempting Install'
17 years 6 months ago #15735 by naveen_rang
Ok. I had the same problem and now I have installed Kunena 1.5.
First i unzipped the downloaded file to a local directory on my computer, then i created a folder called kunena in the tmp folder of Joomla on the server. I uploaded all the unzipped files on my local computer to the tmp/kunena folder.
I ran Install from a Directory and pointed the path to the tmp/kunena folder.
Installation was successful. I guess it is because of the 30 second timeout. As some of us have our sites on shared hostings, it may or may not be possible to get the hosting company to increase the timeout period.
Give this a shot and i am sure it would work.
Naveen
17 years 6 months ago #15748 by Matias
Unfortunately we need to live with this Joomla! 1.5 installer bug -- it's just too slow to install any large component. Unzipping files into the server works usually, because of unzip is the slowest part of component installation.
