Question White page and installation failure.
17 years 7 months ago #11744 by Tryweryn
Hi using joomla 1.5.10 and any version of kunena that I try to install just gives a white page and installation fails. Any idea's and could I maybe try a manual instalation?
17 years 7 months ago - 17 years 7 months ago #11745 by sozzled
Have you checked that your server meets the [url= /forum?func=view&catid=16&id=1447#1449.
]minimum system requirements[/url]?
My recommendation is to use Kunena 1.0.8. There's nothing essentially wrong with Kunena 1.0.9 but it's still very new. There may be traces of previously bad Kunena instals in your SQL tables; you may need to DROP all tables with fb_ prefix.
Last edit: 17 years 7 months ago by sozzled.
17 years 7 months ago - 17 years 7 months ago #11749 by Lintzy
sozzeld, please inform yourself better, before you are telling something about such big affairs.
Quote from DEV-Team:
The Kunena Team is proud to announce the immediate availability of Kunena 1.0.9. This is a security release and all users are urged to upgrade immediately.
This release addresses a number of issues. A legacy security issue inherited form the Fireboard installer has been fixed as well as pagination issues and RSS.
@Tryweryn:
This sounds like the "30-second timeout on Joomla 1.5.x". Please try to install Kunena 1.0.9 from the Webserver. How to do this exactly, can you read here
Last edit: 17 years 7 months ago by Lintzy.
17 years 7 months ago #11792 by core2
You should NOT mess around in your database. Don't drop your tables, you will loose all your data!!!
Which method of installation did you use? from URL, download to own computer and the upload or from local directory on server?
Visit the Kunena documantation .
17 years 6 months ago #14649 by Tryweryn
Hi well tried from an uploaded file and also the normal via joomla. Tried on another site and no problem. Couldnt be the template could it? Is the a way to manually install?
17 years 6 months ago #14653 by Tryweryn
I can see it in admin/components but not in the backend or able to link via menu.
