I installed that module/component after I tried to install kunena. The only two I had installed when I first tried was jomcommment and jomsocial, other than that it was a clean install
Are you sure that's the same DB? I'd contact my hosting provider.
Also Joomlapack should bypass most any server errors. Not just timeouts. Now if your server prevent it from doing what it does you may have other problems.
You can make a clean joomla install in a subdirectory of your production site. Remember to use a different DB prefix. Then try to install Kunena on this clean joomla install.
If you get the same error message on install you have to go over the technical requirement again and then contact your hosting provider.
On the other hand if the install goes without any problems, you have to turn your attention to your production site.
Just a way to exclude some possibilities. And always remember to backup before you do anything!
