Question Installation fails
17 years 8 months ago #9916 by Switch
Installation fails was created by Switch
I tried to install kunena but it fails every time, with the following error:
Fatal error: Class 'mosDBTable' not found in /home/mysite/public_html/components/com_kunena/class.kunena.php on line 826
Any body have any ideas? I searched the forum but couldn't fin anyone with the same problem
Many thanks
17 years 8 months ago #9919 by core2
Replied by core2 on topic Re:Installation fails
You have to provide more information about your site.
docs.kunena.com/index.php/Posting_guidelines
Do your server meet the technical requrement?
docs.kunena.com/index.php/Technical_Requirements
Visit the Kunena documantation .
17 years 8 months ago #9953 by Switch
Replied by Switch on topic Re:Installation fails
My install meets the minimum reqs through the use of php.ini
I am using the latest joomla (1.5.9) and kunena (1.0.8) packages
17 years 7 months ago #9965 by core2
Have you tried to upload the compressed install file to your server end install from local directory? This usually helps if you got a time-out during install. By the way which version of php and mysql-server are you using?
17 years 7 months ago #10012 by Switch
Attempting to install from local directory was one of the first things I tried =/
I'm running mysql 5.0.67 and php 5.2.8
17 years 7 months ago #10034 by core2
- Always a good practice to include as much and precise information as possible in the beginning of a thread!
Maybe joomlapack can help?
