Kunena 7.0.8 Released
Question Issues-Fireboard 1.0.5RC2 - "Report To Moderator"
17 years 6 months ago #1078 by Matias
We need to fix it by ourselves first. Someone of us will answer you soon.
17 years 6 months ago #1079 by fxstein
rhys_daniels wrote:
so which file do i need to edit to customise the "Report To Moderator" email sent to administration.?
The email code is currently in default/plugin/report.php. This will change in future releases.
I suggest you use an IDE like Eclipse. These things are very easy to find if you do a search over the code base. In this case a search for 'report' will get you straight to that file.
Hope this helps!
fxstein
17 years 6 months ago #3270 by rhys_daniels
All done to the way i wanted it. Thanks for the info
Time to create page: 0.306 seconds
