Question Issues-Fireboard 1.0.5RC2 - "Report To Moderator"
17 years 8 months ago - 17 years 8 months ago #931 by rhys_daniels
I want to modify the contents of the email received when a user "Reports To Moderator" from the Fireboard forum.
At the moment it shows the default mail sent.
Can you tell me the file i need to edit to customize the email sent to administrator.
Last edit: 17 years 8 months ago by grumblemarc.
17 years 8 months ago #940 by rhys_daniels
When i use the "Report To Moderator" against a post in Fireboard, the report form will appear correctly. Once i "Send The Report" it will load the homepage and display the fireboard forum in a small section on the homepage. After a short delay it will then redirect to the forum correctly.
For better understanding i have attached a screenshot showing its position. Please can you tell me the fix for this problem. I want the confirmation page to load like as if a new post has been created.
17 years 8 months ago #942 by grumblemarc
Like I asked in another of your posts. Does this problem appear if you switch to the default Joomla template?
17 years 8 months ago #944 by rhys_daniels
Dont know boss, Cant try that suggestion.
17 years 8 months ago #945 by grumblemarc
Then how do you know that your problem isn't Joomla template related/caused? I would be hard pressed to say this is a FireBoard issue if you will not try to help diagnose and pinpoint the problem.
17 years 8 months ago #947 by rhys_daniels
I dont thats the thing, so hoping a fix can be provided without eliminating the template!
