Question installation help
17 years 8 months ago - 17 years 8 months ago #7829 by mattwhipp
installation help was created by mattwhipp
probably sounds obvious but I'm a beginner. So, I've downloaded the zip file, unpacked it, ftp-ed up to a folder in my joomla installation called - logically - forum. Now I'm in the CMS management - as per instructions - installing extension. pointed the URL at mydomain.co.uk/forum. Can't get it to work though. Any ideas what I'm doing wrong? ideally i'd like a single package i can upload direct from my desktop though
Last edit: 17 years 8 months ago by mattwhipp.
17 years 8 months ago #7830 by xillibit
Replied by xillibit on topic Re:installation help
You must copy thanks to your ftp client the files for the kunena forum in the directory tmp and then in the part installation you copy the url which would be http://joomla/tmp, and click on install
17 years 8 months ago #7832 by core2
Replied by core2 on topic Re:installation help
Don't unpack the file, only upload it to your server an in backend, install from directory.
Visit the Kunena documantation .
17 years 8 months ago #7838 by mattwhipp
Replied by mattwhipp on topic Re:installation help
thanks guys - i'll give this a shot
17 years 8 months ago #7841 by mattwhipp
Still having problems. I have copied the installation files into tmp directory of my installation (which is no longer in a directory joomla but at the root). Have uploaded teh zip file into the folder forum. What form should the directory or URLs take to locate them?
17 years 8 months ago - 17 years 8 months ago #7844 by spacereactor
Replied by spacereactor on topic Re:installation help
follow the step.
1.) ftp com_kunena_v1.0.8_b1166_2009-02-17.zip to your site tmp (example www.mystie.com/tmp )
2.) login joomla administrator control.
3.) click extensions ->install/uninstall
4.) locate "Install from URL" enter your www.mysite.com/tmp/com_kunena_v1.0.8_b1166_2009-02-17.zip
5.) it will start to install, after install goto Menus and click NEW and locate kunena forum, give a title and save. Your forum will appear at your frontpage.
P.S You must meet the PHP and Mysql requirement inorder for kunena to work
Last edit: 17 years 8 months ago by spacereactor.
