Question JomSocial Options in Kunena = errors in template
see getfirebug.com/
since the module is off there isn't much i can help. Try out firebug and edit your template css
OK, you can see the module here:
www.clubpeugeot.es/enlaces.html
Thank you if you help me because I was not much to edit the template css
- spacereactor
- Senior Member
- Thank you received: 1
Are you using a Rockettheme on your site as well? These have redefined parameters which can mess up everything from your layout to even your search button.
- spacereactor
- Senior Member
remove style.css at line 1431
.button:hover, .button:focus {background: #333333 none repeat scroll 0 0; border: 1px solid #999999; color:#FFFFFF}
remember to make a backup copy before you edit it.
This problem occurs in various templates
Thanks spacereactor your solution SOLVED the problem in the backend , but the login module problem is NOT RESOLVED
- spacereactor
- Senior Member
