Question JomSocial Options in Kunena = errors in template
17 years 8 months ago - 17 years 8 months ago #7183 by pequeno74
I want to explain changes that occur when select options in kunena configuration.
For example, if you choose to show the avatar of Jomsocial in the registration module this happens.
Check Box, the text and the button will move.
I tried several templates and several modules.
Last edit: 17 years 8 months ago by pequeno74.
17 years 8 months ago #7184 by pequeno74
Another example with another module
17 years 8 months ago #7185 by pequeno74
Another problem. If in Kunena configuration you choose to use JomSocial Messaging, the effect of the buttons on the backend is transformed. When you put the cursor over them turn black.
17 years 8 months ago #7189 by spacereactor
can you post your website link, or you can try to use firebug to see which css messing up
17 years 8 months ago #7205 by pequeno74
This is my site
www.clubpeugeot.es
I log off the modules that you can not see them. Now use a link to register.
¿Firebug?
17 years 8 months ago #7209 by spacereactor
see getfirebug.com/
since the module is off there isn't much i can help. Try out firebug and edit your template css
