Question out of memory on conversion
17 years 9 months ago #6033 by Matias
I don't believe that it's Kunena problem either. Kunena works in my production environment with 64M of memory just fine.
17 years 9 months ago #6037 by sasha fierce
I am really confused; the database that works only has about 2K posts (if not less) than the one that doesn't. Otherwise, everything is able to be populated-- categories, topic titles, etc. If I cut out the message integration, it even populates the users, so I know it's definitely the message text import that is the problem.
I'm just not sure how to correct it.
17 years 9 months ago #6038 by joramilea
after talking to my site host.. the first two errors were being caused by them.
the one I got this morning about /com_kunena/lib/kunena.link.class.php on line 28
as to be because of disagreeing code between the plug in and kunena.
I have fixed the issue by publishing the groupjive cat. and ditching what the readme.txt file says to do with the plug in.
by the way... anyway to hide the recent discussion tab on top of the forums like you can for (HELP) tab?
17 years 9 months ago #6040 by whouse
If worse comes to worse, you could back up your database and restore it locally using something like WAMP or XAMPP installed to do the conversion on your local machine. Then simply backup the local files and put them back on your web server.
17 years 9 months ago #6064 by Matias
FB Converter scripts have one major problem: they try to import all messages once. What they should do is to convert about 5000-10000 messages in one query and then free the memory and continue with next ones.
17 years 9 months ago #6102 by vigge_sWe
this is what I did in administrator/index.php:
error_reporting(E_ALL); ini_set('display_errors', 1); ini_set("memory_limit","32M");
To my suprise, it worked and kunena installed
