Question Help wanted: Template JA Sanidine Error
17 years 9 months ago #4353 by johnnydement
Repelzteeltje wrote:
Okay, that's something I can understand ;)
Meanwhile, is there a dark template already made for 1.08 ?
Otherwise is still can't use Kunena instead of Fireboard :(
I would not recommend using FB due to the security risks involved.
If you check template forum, there's already a dark themed template donefor kunena 1.0.7, should have bigger concerns fixed :)
17 years 9 months ago #4415 by Repelzteeltje
Okay.... anyone who uses Joomlarts Sanidine FB template....
You can make it work in Kunena 1.08 !!
Just copy forum.css to kunena.forum.css ... that will do the trick :laugh:
The only thing needed to fix are the header and footer... they don't fit anymore...
17 years 9 months ago #4454 by Repelzteeltje
Okay... header and footer seem to be okay...
Can anyone help me fix the pathway (something with java ??) and the space beneath the topics (pagination)
You can see it here: www.webbr.nl/forum2
17 years 9 months ago #4460 by johnnydement
please, notice that doing so, would be same as reverting to fireboard... you will suffer from nearly all the security issues it had...
17 years 9 months ago #4461 by grumblemarc
I think I previously mentioned that there were some CSS and code changes to the Kunena templates. Simply replacing a CSS file was a faulty patch at best. I would o back to the template designer and STRONGLY recommend that they update their template. However since they created for use with FB there is no guarantee that they will since they aren't really obligated to.
17 years 9 months ago #4476 by Repelzteeltje
Believe me.. I really want to use Kunena instead of Fireboard...
I've send a email to Joomlart so I'll have to wait for an answer :angry: ( and I think Grumble is right... they don't have to do shit...)
To only thing I can't understand is why you guys cab change an existing FB-template to a Kunena-template and then say to me that it isn't possible...
If someone can say WHAT is changed, you will help a lot of people who are strugling to make there template to work...
In my opinion it's just a css thing so why does it alter the security ?
Maybe there is a admin who can help me convert the template ?
I'm just asking for support, even though I paid for my template...
Excuse me for any errors in my English... I can do it better in Dutch ;)
