Question White screen when installing
17 years 9 months ago #3009 by fxstein
XQLUSIVE wrote:
As i said before, we already tried that, and we did manage to install Kunena, but with alot of errors because Kunena tried to create a lot of MySQL tables which didn't exist.
So the Kunena installation was useless :(
I am not sure I understand. Yes Kunena needs to create MySQL tables if it is a new install. If the creation of these tables fails, it might be a MySQL permissions problem.
If the install failed on a timeout before you might have to manually remove those jos_fb_xxxxx tables in your database and re-run the install.
Hope this helps!
fxstein
17 years 9 months ago #3128 by XQLUSIVE
The Kunena installation is trying to apply data to some MySQL tables which doesn't exist. That is impossible...
17 years 9 months ago #3196 by Matias
Your installation has failed (timeout).
17 years 9 months ago #3253 by XQLUSIVE
I guess i have to try again. I return if something good or bad happens :)
17 years 9 months ago - 17 years 9 months ago #3627 by XQLUSIVE
We tried to install Kunena again, and we got the same errors as last time, except from the MySQL errors.
Take a look at this...
img152.imageshack.us/img152/6679/kunenaerrornf8.jpg
Last edit: 17 years 9 months ago by XQLUSIVE.
17 years 9 months ago #3631 by fxstein
Unfortunately the error messages cut off in your picture. We would need to see the entire output to see the error.
fxstein
