Question White screen when installing
How come i can't install it?
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
www.kunena.com/index.php?option=com_kune...iew&catid=16&id=2761
We noticed that Apache cancelled the installation because it exceeded the timelimit.
We tried to change it, and we installed it, but not without errors. The Kunena installation tried to create some MySQL entries which didn't exist, and that resulted in several errors, and the installation was useless.
No, it ain't the same.
Unfortunately this is a very common issue on Joomla 1.5. The installer is very slow and packages as small as 300k can easily time out.
The work around for this is to set the php timeout variable from default 30s to something like 120s. (etc/php.ini)
The very same effect can be accomplished by adding the following line into the index.php file of your backend:
/administrator/index.php
right after:
add:
Hope this helps!
fxstein
So the Kunena installation was useless
