Kunena 7.0.8 Released
Question Apostrophes in Subject Heading Cause [Example\’s]
17 years 4 months ago - 17 years 4 months ago #11003 by sozzled
grumblemarc wrote:
I would always recommend upgrading to the latest STABLE version. Make your decision to upgrade, or not, based on your own research and not something you "heard".
Yes, I fully support what g'marc says: use the latest stable version.
For the time being, until the dust has settled following the recently announced Kunena 1.0.9, I would recommend that you instal Kunena 1.0.8 because that version has been stable for over two months.
Last edit: 17 years 4 months ago by sozzled.
17 years 4 months ago #11004 by trew01
Replied by trew01 on topic Re:Upgrading from
ok thank you both very much so i have a question can i just upgrade over the existing fireboard or fresh install? I want all my settings kept the same and posts etc... any advice on this?
17 years 4 months ago #11005 by trew01
forgot to add this is what i meant by intergrations. showing he forum posts and rank etc through CB and syncing them like FB does with CB kunena.uservoice.com/pages/general/sugge...-integration?lang=en
17 years 4 months ago #11006 by sozzled
See www.kunena.com/forum?func=view&catid=19&id=1280nolder for the installation guide.
17 years 4 months ago - 17 years 4 months ago #11008 by sozzled
Replied by sozzled on topic CB integration with Kunena
See the third paragraph of my post ( #11000 ) for further information on what you might need to consider.
17 years 4 months ago - 17 years 4 months ago #11015 by trew01
wow that post seems complex. s will it retain everything from the community builder intergration with the forums to all my settings and users being synced with CB and Kunena? (yes i asked this but wasnt clearly stated) and upgrading from 1.0.3 FB to 1.0.4 then i ahve to use a converter i cant fine plus upgrade after to 1.0.5 FB and then finally uninstall FB and the converter and install Kunena? wow...
ok so our forums are brand new would it just be easier to delete and uninstall all of FB and just do a fresh install of 1.0.8 kunena? and will it still allow intergrating between syncing etc... and users etc... of Community builder? thanks I know im repeating but im not clearly understanding sorry..
will I need to get a new plugin for CB to work with kunena? is one availible? i dont mind instlling fresh but i would need to remove moduels etc...
fyi our joomla is version 1.5 legacy if you needed to know.
Last edit: 17 years 4 months ago by trew01.
