Question Apostrophes in Subject Heading Cause [Example\’s]
Yes, I fully support what g'marc says: use the latest stable version.I would always recommend upgrading to the latest STABLE version. Make your decision to upgrade, or not, based on your own research and not something you "heard".
For the time being, until the dust has settled following the recently announced Kunena 1.0.9, I would recommend that you instal Kunena 1.0.8 because that version has been stable for over two months.
See www.kunena.com/forum?func=view&catid=19&id=1280nolder for the installation guide.ok thank you both very much so i have a question can i just upgrade over the existing fireboard or fresh install? I want all my settings kept the same and posts etc... any advice on this?
See the third paragraph of my post ( #11000 ) for further information on what you might need to consider.forgot to add this is what i meant by intergrations. showing he forum posts and rank etc through CB and syncing them like FB does with CB kunena.uservoice.com/pages/general/sugge...-integration?lang=en
ok so our forums are brand new would it just be easier to delete and uninstall all of FB and just do a fresh install of 1.0.8 kunena? and will it still allow intergrating between syncing etc... and users etc... of Community builder? thanks I know im repeating but im not clearly understanding sorry..
will I need to get a new plugin for CB to work with kunena? is one availible? i dont mind instlling fresh but i would need to remove moduels etc...
fyi our joomla is version 1.5 legacy if you needed to know.
