Solved 6.3.2 Running Slow
2 years 4 months ago #231777 by rich
Replied by rich on topic 6.3.2 Running Slow
I'm not sure I understand, though. First, all the duplicates are already disabled (unpublished), both in the Kunena menu and the main menu.
Unfortunately, the problem is that deactivated menu items can also cause errors. This even happens with menu items in Trash.
When I start a new class, I create a new forum just for that class - Twist was one class, Garden is another, and there will be more in the future
The easiest way in your case would be to create a separate user group for each school class. Then you would no longer need extra menu items, the original menu created by Kunena would be sufficient.
You can see how it works here: docs.kunena.org/en/faq/categories-only-for-certain-user-groups
2 years 4 months ago #231780 by mberman
Replied by mberman on topic 6.3.2 Running Slow
Ok, I did all that - trashed all the duplicate menu items and emptied trash, created separate user groups for each class and assigned students, set category permissions. It all works fine, except that it still takes a long time for the Index page to load.
Anything else I can try?
Thanks,
Matt
2 years 4 months ago #231781 by mberman
In case it is helpful, here is the latest config. report after the changes.
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 500M | Max file upload:
Joomla default template details : dickensu | author:  | version:  | creationdate: Unknown
Kunena default template details : Aurelia | author: Kunena Team | version: 6.3.2 | creationdate: 2024-06-14
Kunena template params:
Kunena version detailed: Kunena 6.3.2 | 2024-06-14 [ Git Repository ]
Plugins: None
2 years 4 months ago #231783 by rich
The menu items are ok now except the menu item in the main menu. This must be a Menu Item Type = Menu Item Alias ( see here ).
Delete this menu item and create instead a new menu item alias.
The following user(s) said Thank You: mberman
2 years 4 months ago #231785 by mberman
Well, HALLELUJAH! I've spent literally a week and a half trying to figure this out, and you do it in a few messages. I should have come here first.
Thank you so much! You just saved my class.
Matt
Time to create page: 0.153 seconds
