Solved Post moderation and actions button do not work
4 years 2 months ago - 4 years 2 months ago #225444 by uzbaby
  After mirgation to Joomla 4 when I enter to kunena topic and want to moderate it or make some action that buttons do not work.
YOu can see in the attachment which buttons I mean.
They do not make any movement when I press them.
Please can you help me?
Here is my Report configuration
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 512M | Max file upload:
Joomla default template details : joomlalove_sempatic | author: Joomlalove.com | version: 2.0.9 | creationdate: 2022
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.3 | creationdate: 2022-09-22
Kunena template params:
Kunena version detailed: Kunena 6.0.3 | 2022-09-22 [ Git Repository ]
Plugins: None
Last edit: 4 years 2 months ago by uzbaby.
4 years 2 months ago #225445 by Leen
I think you are using a Helix Ultimate based template.
so see if it works if you use the kunena Template : Set Aurelia as my image and save it.
Or test it first with the default joomla template.
With kind regards
Leen
4 years 2 months ago #225446 by uzbaby
    Thank you
Yes, I use Helix
But Kunena Template is Aurelia
Everything set as you said
You can see the attachment
4 years 2 months ago #225447 by Leen
And it still doesn't work?
and if you disable the bootstrap.css
sometimes that can be just, it is possible that another is loaded
www.kunena.org/forum/k6-0-support-archiv...s-not-working#224055
With kind regards
Leen
4 years 2 months ago - 4 years 2 months ago #225448 by Leen
And works for myself on one of my websites only if I go into administrator > templates at the Helix Ultimate in the folder js "bootstrap.bundle.min.js" rename(see image)
With kind regards
Leen
Last edit: 4 years 2 months ago by Leen.
4 years 1 month ago #225460 by uzbaby
Dear Leen!
This ( www.kunena.org/forum/k6-0-support-archiv...s-not-working#224055 ) worked perfectly. Thank you very much!
Time to create page: 0.183 seconds
