Question Problem I do not have icons and I can not attach files
8 years 6 months ago - 8 years 6 months ago #199850 by neon26
Hello
As you can see in the picture, I do not get the icons that usually come out, for example to put a link or others.
Another problem is that I give the button attach images for example and it does not work, does not do anything that button.
Yesterday I installed joomla 3.8.8 and kunena 5.1, so I do not know where the problem might come from
Can you help me?
Thank you
attached report here...
Last edit: 8 years 6 months ago by neon26.
8 years 6 months ago - 8 years 6 months ago #199892 by neon26
Can anyone help me?
I've also seen that the menu disappears when I'm going to answer an answer
in this photo menu is ok
in this photo menu disappears
8 years 6 months ago #199976 by guidocx84
Also me with attachments problems after kunena 5.1 upgrade. I click on inserti in the message button but it doesn't insert the file :dry:
8 years 6 months ago #199977 by 810
try the nightly build. its on our download page.
For the editor, go to the kunena template options, and click on save.
8 years 6 months ago #199983 by guidocx84
810 wrote: try the nightly build. its on our download page.
Do you think that the nightly build will solve the problem? Do you suggest me to install it on a production environment?
I'm facing also problems with FontAwesome, also taking them from external CDN. I see big "!" and "?" animated when I pass the mouse over the online user section.
8 years 6 months ago #199996 by neon26
what is this? nightly build
Where I can find it? and what do I have to do,
i don´t undertand
Time to create page: 0.163 seconds
