Question Problems with Kunena 5.1.0
8 years 6 months ago #199852 by Bouma
Replied by Bouma on topic Problems with Kunena 5.1.0
I am facing the same problem, did what you suggested with nightly build, and even reset the menu. Still facing the same issue.
/index.php/datapad/edit-forum-profile/join-requests/202-joining-the-forum#1075
Happen on latest post, Categories and forums.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 768M | Max file upload: 128M
Joomla default template details : g5_helium | author: RocketTheme, LLC | version: 5.4.23 | creationdate: February 20, 2018
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.2 | creationdate: 2017-01-09
Kunena template params:
Kunena version detailed: Kunena 5.1.1-DEV | 2018-05-23 [ Internal ]
Third-party components: CommunityBuilder 2.1.4 | UddeIM 3.9
Plugins: Search - Kunena Search 5.1.0 | Content - Kunena Discuss 5.1.0
Modules: Kunena Latest 5.1.0 | Kunena Stats 5.1.0 | Kunena Login 5.1.0 | Kunena Search 5.1.0
8 years 6 months ago #199873 by rich
Replied by rich on topic Problems with Kunena 5.1.0
You use still Blue Eagle 1.0.2. Please try it with Blue Eagle 5 v1.5.0 RC2.
www.kunena.org/download/templates/category/blue-eagle-5
Important! Backup your custom images and CSS codes previously, which you've changed in your template.
If you have questions specially about Blue Eagle, then in this category please:
www.kunena.org/forum/blue-eagle-5
8 years 6 months ago - 8 years 6 months ago #199931 by Bouma
rich wrote: You use still Blue Eagle 1.0.2. Please try it with Blue Eagle 5 v1.5.0 RC2.
Thanks for the input rich, but sadly, it didn't fix the problem. It still has the same issue.
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.0 | creationdate: 2017-08-30
Last edit: 8 years 6 months ago by Bouma.
8 years 6 months ago #199980 by Bouma
Time to create page: 0.168 seconds
