Question Problems after upgrade 5.0.3
10 years 2 weeks ago #181353 by salvo_kunena
Good morning, after upgrade 5.0.3 it no longer appears the index of categories of kunea forum. Why?
Thank you.
www.hera.it/forum-login-registrati
10 years 2 weeks ago #181354 by lagad
Replied by lagad on topic Problems after upgrade 5.0.3
Did you :
enable "Load Bootstrap" option on the crypsis settings ?
check this post : www.kunena.org/forum/installation-issues...lem-for-kunena-5-0-2 ?
10 years 2 weeks ago #181356 by salvo_kunena
This I have already done. but I have not solved the problem
10 years 2 weeks ago #181363 by 810
Replied by 810 on topic Problems after upgrade 5.0.3
looks like the forum is only visible for users.
I think you have enable registered only option, on the kunena configuration - security tab
10 years 2 weeks ago #181371 by salvo_kunena
I disabled visitors to post or display. But it was before making the upgrade to 5.0.3 as in the attached file.
10 years 2 weeks ago #181373 by 810
ok, you just want a login box?
then add the login module on position kunena_top and only visible for guests and set it to horizontal.
