- Thank you received: 11
Solved Kunena 5.0.1 language strings problem (COM_KUNENA_X_TOPICS etc)
- anonymous01
- Premium Member
810 wrote: Ok, fixed, check updater
Strange ... I again received after update "COM_KUNENA_X_TOPICS".
Language by default on the site: Russian,
Forum Options -> "Use English in the missing lines" -> Yes.
- anonymous01
- Premium Member
- Thank you received: 2545
But a copied category loads the strings correct. On a new installations it also works (I've tested it on 2 different pages). Maybe there is this problem also with other languages.
- kunenauser40
- Junior Member
- Thank you received: 9
I installed from the joomla updater the fix and the problem solved.
Some strings that before was translated to Greek corectly now are in English, but it's very small problem because the most are correct and the problem with the COM_KUNENA_X_ etc has fixed.
Thanks again !
