Solved Preview not working [Reopend] Kunena page address problem?
10 years 2 months ago - 10 years 2 months ago #174013 by Celt
I have a preview issue as well without images or video in the posts, so I'm not sure if the reply to the OP's problem is going to be the same to me?
The site is a totally new build on J 3.5.
Firebug Error message:
"NetworkError: 500 Layout common/menu not found. - http://mydomain.uk/forum/topic/edit.raw"
I turned on the Joomla and Kunena debugging and there are no reported errors. The only output is the Joomla Debug Console > Session Tab.
Kunena Config Data:
If you need any more information or admin access to the site let me know.
Thanks for all the work you guys do developing Kunena and all the support here on the forum - it's much appreciated. :)
Last edit: 10 years 2 months ago by Celt.
10 years 2 months ago #174014 by xillibit
Replied by xillibit on topic Preview not working
This layout doesn't exist under Crypsis : Layout common/menu not found
Is-it an update of Kunena or a clean install ?
10 years 2 months ago #174015 by Celt
Replied by Celt on topic Preview not working
It is on a clean installation.
10 years 2 months ago - 10 years 2 months ago #174017 by xillibit
Try to uninstall Kuena and re-install it, i think that a file is broken
Last edit: 10 years 2 months ago by xillibit.
10 years 2 months ago #174020 by Celt
Hi xillibit,
Thanks for your reply. I have reinstalled Kunena and the preview still doesn't work. I tried with the installed template and Protostar.
10 years 2 months ago #174025 by rich
Replied by rich on topic Preview not working
Celt wrote: It is on a clean installation.
You mean with clean installation only Joomla and Kunena, or have you also installed others extensions which are not listed in the configuration report?
Time to create page: 0.265 seconds
