Question J3 to J4 problem
Attachment not found
- Thank you received: 2545
This is the way it has always worked in my tests. But it should also work if Kunena was not previously uninstalled via the Joomla installer.
Your problem seems to have to do with the permissions. Please check these, folders should be chmod 0755 and files 0644.
I found the upgrade guide in the link you provided after I had created this problem. I didn't uninstall before migrating to J4. I did run a permissions fix through Akeeba AdminTools and double-checked that all files and folders had correct permissions.
I should point out that the migration to J4 was done with Migrate Me software. So I still have the J3 site active. The migration is in a temp folder "[ROOT]/mm4/". While I could go back and rerun the migration... doing so would cost me 2 days of getting everything else smoothed out in the J4 installation.
I changed .htaccess of the "mm4" folder to point the root to the "mm4" folder, but the error messages (see pic in first post) show "[ROOT]/administrator..." Could that be why it's not installing correctly? Is the installation not recognizing that the "root" is in "mm4"?
$log_path = '/home/[myusername]/public_html/mm4/logs';
I tried changing $livesite from '' to ' myurl.com/mm4/ ' but that didn't help.
