Question Kunena Help (menu item for users) in my J5 website: error 'deprecated $body'
2 years 5 months ago #229809 by rich
Is there any other place in the dashboard, where I can switch off debugging, or any other background service?
No, there is no other place to deactivate the debug. However, it could be that the page is loaded from the cache together with the displayed error.
But the error has been fixed in the meantime, see here: github.com/Kunena/Kunena-Forum/commit/26...015bb6d6ca32f93d29e3
2 years 5 months ago #229810 by Leen
I have my wamp set up like this and I have that problem not so maybe you can compare setting wamp
With kind regards
Leen
2 years 5 months ago #229812 by sthop
Thank you for your answer.
I expect that the reparation of 'deprecated $body' will show up in the next update-version of Kunena: v.6.2.1 ?
2 years 5 months ago #229813 by xillibit
hello,
yes the fix for will be present in the Kunena 6.2.1
2 years 5 months ago #229815 by sthop
Hoi Leen,
Thank you for your .JPG screenshots.
I compared my WampServer-PHP settings with your screenshot and found 3 differences:
Three settings are different in my php.ini:
ON:    display_errors        ✓
ON:    display_startup_errors    ✓
OFF:    xdebug.show_local_vars    -
Today, I have been experimenting with these settings, but I find 3 instances of php.ini:
Two in ..\wamp64\bin\php\php8.2.0\ :
1) php.ini and 2) phpForApache.ini
One in ..C:\wamp64\bin\apache\apache2.4.54.2\bin\ :
3) php.ini .
A. Display_Errors in php8.2.0
php.ini : When I write manually in php.ini 'display_errors = off', it has no effect on the Help-webpage: error is still displayed.
If I click on de PHP-setting in WampServer (as shown in your screenshot), then WampServer changes display_errors to OFF in phpForApache.ini ! This also does not make the error go away.
In WampServer, I clicked on 'Restart from Zero' (to cleanup possible caches?).
B. Display_Startup_Errors
Setting Display_Startup_Errors to Off had no effect either.
But: Now my website (frontend + backend) has crashed altogether: I get a MyQSLi error:
The MySQLi extension is not available
Joomla\Database\Exception\
A. UnsupportedAdapterException 1
in ..\wamp64\www\joomla4\libraries\vendor\joomla\database\src\Mysqli\MysqliDriver.php (line 198)
            return;        }        // Make sure the MySQLi extension for PHP is installed and enabled.        if (!static::isSupported()) {            throw new UnsupportedAdapterException('The MySQLi extension is not available');        }        /*         * Unlike mysql_connect(), mysqli_connect() takes the port and socket as separate arguments. Therefore, we         * have to extract them from the host string.
MysqliDriver->connect()
in ..\wamp64\www\joomla4\libraries\vendor\joomla\database\src\Mysqli\MysqliDriver.php (line 394)
B. UnsupportedAdapterException 2
in ..\wamp64\www\joomla4\libraries\vendor\joomla\session\src\Handler\DatabaseHandler.php (line 223)
I restarted my laptop, but the Mysqi crash is still there.
So, now I am stuck!
Should I reinstall Joomla 5 or reinstall WampServer?
Regards, sthop
Windows11, Apache 2.4.54 (Win64), MariaDB 10.10.2, PHP 8.2.0, mod_fcgid 2.3.10-dev
2 years 5 months ago #229816 by sthop
Hoi Leen,
Sorry to bother you again.
I found the cause of the crash: I forgot the ';' before my comment line in php.ini (stupid me).
The original Kunena-Forum-Help webpage in my site still remains, though.
Another problem arose:
In your screenshot about the PHP-settings in WampServer: the list displays the parameters neatly beneath each other. That was the case in my WampServer too, but for some strange reason, I now have a laptop-screen display problem (only with WampServer: PHP Settings option)
The long list of parameters is now shown in a long horizontal order that disappears to the right beyond the limit of my screen. So, I cannot see many parameters or reach them with my mouse.
How can I correct the display options of WampServer Menu?
Regards, Sthop
Time to create page: 0.273 seconds
