Question Emoticons in posts are not displayed
3 years 1 month ago #229564 by Gindi
Yes, the 00003127.gif is in the /media/kunena/emoticons directory.
I have now additionally installed the same smilie again in the post where the smilie is not displayed and this time the smilie is displayed.
When I click on source code, I see the difference.
In the source code of the smilie that is not displayed, between [img] and [/img] it says /media/kunena/emoticons/00003127.gif
In the source code of the smilie that is displayed, it says between [img] and [/img] /BFB434test/media/kunena/emoticons/00003127.gif
But it can't be the Akeeba backup because I exported the database table and the /emoticons directory directly from the Lifesite and imported it in the test server.
Gindi
3 years 1 month ago #229565 by rich
Now I see the cause. If you copy the test page back to the live page, the smilies work again. It seems that the live page is installed on root, and locally in a subfolder. This changes the path from:
to
3 years 1 month ago - 3 years 1 month ago #229566 by Gindi
What I do not understand is that in posts older than 1 year, the smilies are displayed and in posts newer date in the same topic not.
Gindi
I have now found the difference why the older smilies are displayed and the newer ones are not.
The older smilies show the code in the source code and the newer smilies show the URL.
I have now deleted the URL of the smiley in the Lifesite in the post and entered the code for it. The smilie was also displayed with code.
Then I made a backup and installed in the test server.
The smilie was displayed on the test server.
Is it possible to set the editor to insert the code of the smilie and not the URL?
Then the problem would be solved.
Gindi
Last edit: 3 years 1 month ago by Gindi.
3 years 1 month ago #229609 by rich
Yes, it works with the codes. But then the smileys are not displayed in the editor preview. Is that the same for you?
3 years 1 month ago - 3 years 1 month ago #229611 by Gindi
How is that meant?
Are the smilies not shown in the menu bar or in the selection window or after the selection in the text field?
Can I change something in a file somewhere to try this out?
Or is it meant that when editing in the text field instead of [img now the code (eg :rain:) is?
That would be OK for me.
Gindi
Last edit: 3 years 1 month ago by Gindi. Reason: Nachtrag editieren
3 years 1 month ago #229636 by rich
I meant the text box. I'll write a ticket on Git, then we'll see what the best solution is.
