Solved My messages can not be read properly
- henery_smith
I am using cloudbase 3
Above is the screenshot of the message that I posted in my Kuena Forum
Only this post is affected
My other posts are not affected
Please advise as to what I should do
By the way I am a beginner and so please use simple language and not code language
- Thank you received: 2544
It seems to me, this is a copied text passage, which have been copied and pasted along with the hidden codes.Only this post is affected
The easiest way, if you edit the message and remove this content. Afterwards, write this text new. But first make a copy of this text, so you have a pattern from this message.
This text was in pdf format and I converted it to word
I then copied the text from word and pasted it to make a post.
I usually do this and the post comes okay.
this time I find that the messages is all jumbled up and I can not read the post.
I am also finding it difficult to delete the post.
Please advise how I can delete this post
Where is the problem? You just need to click on the "Delete" button below the message. Don't you have moderator or admin access?I am also finding it difficult to delete the post.
