Solved Logout and Login Issues
5 years 3 weeks ago #219479 by nickza
Hi. I did all of that, and more. and its all sorted now. The site had a lot of issues which have been sorted.
Another factor was www. and non www. The site default is with www., so users who visited non-www where getting logged out.
Thank you for your help
641 Profile mainmenu view=userprofile
637 Forum footer view=home&defaultmenu=207forum-2
215 Forum sidemenu view=home&defaultmenu=207forum-3
1. Trash these 3 menu items
2. Empty the menu trash
3. Use the Kunena Dashboard: Tools -> Menu Manager -> Restore Kunena Menu facility.
4. Publish the menu item created for you in your top-level/main menu
Now test login/logout works correct.
If you want extra menu items in other menus. you must use Syshtem Links - Menu Item Alias (see  Menu Issues  and Menu Tips ).
If the menus are correct, you can use the name Forum as often as you want.
