Solved Call to an undefined method kunenauser::getName()
5 years 7 months ago - 5 years 7 months ago #216405 by crimle
Thank you. Here is the config report you were asking for.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : yoo_helios | author: YOOtheme | version: 1.0.10 | creationdate: September 2016
Kunena default template details : NTS KPop | author: Nice Theme Store | version: 1.1.2 | creationdate: 2021-03-09
Kunena template params:
Kunena version detailed: Kunena 5.2.2 | 2021-01-13 [ Iris ]
Third-party components: UddeIM 3.9
Plugins: Search - Kunena Search 5.2.1
Modules: Kunena Latest 5.2.1 | Kunena Search 5.2.1
Last edit: 5 years 7 months ago by xillibit.
5 years 7 months ago - 5 years 7 months ago #216408 by Jeazac
I checked your site and i goes on Akeeba Backup Site Restoration Script
Yes, I couldn't leave a big "oops" for my community and since I had installed the mods and plugins and nothing had changed, I had no choice but to restore the backup I had made just before.
sorry for the off-topic, you can delete my messages
Last edit: 5 years 7 months ago by Jeazac.
5 years 7 months ago #216447 by xillibit
@Crimle: if you switch to Crypsis template do-you have the same issue ? i don't know if the template NTS KPop has been updated with the changes made in Kunena 5.2.3
5 years 7 months ago #216479 by rich
Yes, an update is available:
NTS KPop Last update Mar 09, 2021 Compatibilit Kunena 5.2.3
5 years 7 months ago #216515 by crimle
The issue seems to be related to «NTS KPop» template although we are using the latest version dated 2021-03-09. With Crypsis template, it works. Thank you for the input.
Time to create page: 0.164 seconds
