Solved Call to an undefined method kunenauser::getName()
5 years 7 months ago #216382 by crimle
After upgrading from Kunena 5.2.2 to Kunena 5.2.3 I am getting an error message, when saving a new post or an answer:
Nevertheless the post is saved correctly, but the error message is ugly:
Thank you and kind regards
Chris
5 years 7 months ago #216387 by xillibit
If you are using blue eagle template, do-you have updated it to 1.6.3 version ? If you are using Kunena addons (modules and plugins) do-you have updated it to version 5.2.1 ?
5 years 7 months ago - 5 years 7 months ago #216389 by Jeazac
same here : www.zephyrclub.fr/forum/index
I use Crypsis and I reinstalled all the mods and plugins on this page : github.com/Kunena/Kunena-Addons/releases/tag/5.2.1
Nothing works
Last edit: 5 years 7 months ago by Jeazac.
5 years 7 months ago #216391 by xillibit
I checked your site and i goes on Akeeba Backup Site Restoration Script
5 years 7 months ago #216401 by crimle
The template I am using is NTS KPop 1.1.2 2021-03-09.
Some of the addons are 5.2.1, some are 5.2.2, some are 5.2.3 and there is even a component on 3.0.8 (the administrator component).Kunena - Joomla Integration Site Plugin 5.2.2 2021-01-13 Kunena - Kunena Integration Site Plugin 5.2.2 2021-01-13 Kunena - UddeIM Integration Site Plugin 5.2.2 2021-01-13 Kunena Forum Site Komponente 5.2.2 2021-01-13 Kunena Forum Administrator Komponente 3.0.8 2015-04-05 Kunena Forum Package Site Paket 5.2.2 2021-01-13 Kunena Framework Site Bibliothek 5.2.2 2021-01-13 Kunena Language - English Site Datei 5.2.3 2021-03-07 Kunena Language - German (Germany) Site Datei 5.2.3 2021-03-07 Kunena Language Pack Site Paket 5.2.3 2021-03-07 Kunena Latest Site Modul 5.2.1 2021-03-08 Kunena Media Files Site Datei 5.2.2 2021-01-13 Kunena Search Site Modul 5.2.1 2021-03-08 Quick Icon - Kunena Forum Site Plugin 5.2.2 2021-01-13 System - Kunena Forum Site Plugin 5.2.2 2021-01-13
5 years 7 months ago #216404 by xillibit
Please put here your Kunena report configuration settings, it's contains all the info about version and it's more easier to read
