Solved Problem with kunena 5.2
5 years 9 months ago - 5 years 9 months ago #215398 by rich
Replied by rich on topic Problem with kunena 5.2
If you use Blue Eagle it's not the same. An update of Blue Eagle solves the problem.
Last edit: 5 years 9 months ago by rich.
5 years 9 months ago #215479 by feliwebwork
Replied by feliwebwork on topic Problem with kunena 5.2
rich wrote: If you use Blue Eagle it's not the same. An update of
But Blue Eagle is a paid product. We are talking about the default Crypsis template that comes with Kunena, which should be a working template.
5 years 9 months ago - 5 years 9 months ago #215482 by rich
I'm sorry, but when user writes "I have the same issue" I can only guess. And a similar error was in Blue Eagle too.
See here, maybe is that the solution for you:  www.kunena.org/forum/k-5-2-support-archi...after-upgrade#215401
5 years 9 months ago #215525 by feliwebwork
Thanks, the link you put did help with my issue.
By the way, when I use the "quote" function, even on this site, it puts my typing within the quoted text. So that is not working correctly.
