Solved Problem with kunena 5.2
5 years 10 months ago #214736 by kunenauser40
I just update from previous version of kunena (5.1.19) to 5.2 and I have latest Joomla! installed.
The problem is when you go to create a post or to reply to a post, the emotions bar and all the formatting tools as I show you to the photo are missing and the only is displayed is the subject and the main box to write the text of the post, no emotions to select, no formatting tools (e.g. bold / underline etc)
Before the update I had not that problem and I did not change anything.
I also cleared cache but I still have the problem.
I add my configuration report if it helps. So how can I fix that? Thanks.
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.0 | creationdate: 2020-12-09
Kunena template params:
Kunena version detailed: Kunena 5.2.0 | 2020-12-09 [ Nyx ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.1.2
Modules: Kunena Latest 5.1.2
5 years 10 months ago #214738 by rich
Replied by rich on topic Problem with kunena 5.2
It seems the editor will not loaded correctly. Please empty the Joomla cache and then reload the page with Strg+F5.
5 years 10 months ago #214740 by kunenauser40
I cleared cache 4-5 times from joomla (Clear cache / Clear expired cache), I used Ctrl-F5 in browser, also I emptied browser cache and I tried in Firefox and in Google Chrome latest version and the problem remains.
I also tried to manually delete the files via FTP in cache / kunena, but again the problem remains.
If it helps, I noticed after the update that except the editor missing, also the Legend was not displayed (which writes at the bottom of the page the colors of users e.g. red is Site Administrator, blue is moderator etc) but after some minutes and by cleared cache it appeared, but the editor still not appeared for some hours ago)
5 years 10 months ago #214741 by kunenauser40
I just found the problem,so to inform you, it was caused by a plugin for combine html / css / javascript for better speed.
I tried to change some settings there and kunena works OK now, editor loads OK!
Thank you for your reply rich.
5 years 9 months ago #215388 by feliwebwork
Replied by feliwebwork on topic Problem with kunena 5.2
Could you please explain how you fixed it step by step as I am having the same problem.
5 years 9 months ago #215393 by gioy_80
Replied by gioy_80 on topic Problem with kunena 5.2
I have the same issue too... if anyone haves the solution can he explain how he has resolved?
Thank you!
Time to create page: 0.177 seconds
