Solved attachments do not upload correctly and user problems
10 years 9 months ago - 10 years 9 months ago #171823 by DrRip
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : Prismatic-for-Joomla-3.X | author: Crosstec GmbH & Co. KG | version: 1.5 | creationdate: July 2014
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Kunena version detailed: Kunena 4.0.7 | 2015-11-16 [ Albareto ]
Third-party components: UddeIM 3.4
Plugins: Search - Kunena Search 3.1.1 | Content - Kunena Discuss 3.1.1
Modules: Kunena Latest 3.1.1.1
Dear Kunena Support,
We updated Kunena to 4.0.7 and some Problems occured. When trying to upload attachments these are uploaded and we see them on the server, but they are not shown in the topic. We get an error telling us Anhang kann nicht gespeichert werden: Datei „/“ existiert nicht! (attachment could not be saved: File "/" does not exist).
Furthermore we cannot acces Userprofiles of old Users in the frontend, but newly registered users can be viewed. When trying to view an "old" user we get 500 Internal Server Error.
In the backend we can see all users with correct information.
We hope you can help us here,
thanks
Rip
Last edit: 10 years 9 months ago by DrRip.
10 years 9 months ago #171824 by 810
go to backend - kunena - template manager - set the blue eagle version 4.0.7 as default template.
I see now the Blue eagle v3.0.6 is set as default.
The following user(s) said Thank You: DrRip
10 years 9 months ago - 10 years 9 months ago #171828 by DrRip
Thx,
the problem viewing the Users is gone, now we get the error: "No valid image was loaded" every time we try to add an atachement.
We use Crypsis 4.0.3 atm.
Now changed to Blue Eagle 4.0.7
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.7 | creationdate: 2015-11-16
Viewing Users works but the error when uploading images stays the same as in the first post.
10 years 9 months ago #171830 by 810
should be crypsis v4.0.7
So I think some files are not overwriten by the update.
Try to fix the permissions with admin tools, then try install kunena again.
10 years 9 months ago #171955 by DrRip
we tried a install, after making sure files can be written to our joomla directory.
But the upload problem persists. Crypsis tells: No valid image was found, Blue Eagle tells us File "/" does not exist.
any more tips?
10 years 9 months ago #171956 by 810
we just released k4.0.8 try to update, and try again.
Time to create page: 0.212 seconds
