- Thank you received: 1425
Question installation failure
first cleaned my database. Removed all "kunena" and all "kun". And did a search for: Forum Package.
Second. Compared the 2 Joomla's. no significant differences.
Third. In Joomla admin / extensions / manage I have off all non-native extensions except Community Builder.
And then try to install Kunena. Same error.
O.K. Now I will do the cleaning again. Have also CB off and try to install Kunena.
And will use utf8
Don't use the htaccess.
utf8_general_ci DB collatie was already chosen from the beginning.
The issue remains. I cannot go into CB administration. But I have to. My deadline is approaching.
Perhaps (but I'm not sure) I tried to install Kunena in CB plugin manager. I remember a few weeks ago, when I looked at it for the first time, it gave me a error.
Joomla: utf8_general_ci
and CB: utf8_mb4_general_ci
As I don't have any knowledge on this particular item, what to do?
try new site.
First install kunena. Check its working, then install cb.
The collation isn't the problem.
Fresh Joomla 3.4.4 in MAMP/htdocs/Zaterdag
Fresh Kunena 4.0.5 installation via admin/extentions/upload package
the installation starts and stops after a few seconds.
Now there is a Kunena dashboard in admin/components, but redirecting to the errormessage.
Also the database shows the Kunena items.
I have not yet installed CB.
