Question installation failure
In my MAMP/localhost I do have 2 installations of Joomla. The first is clear, it has only a Kunena installation. Is working perfect.
I work in the 2nd one. Most on Community Builder. It is in this Joomla that I cannot install Kunena. After a few seconds the installation stops. In administrator/Components I see Kunena, but when I klick on it I go back to the error message.
I remove everything as far as I know, in admin and in phpMyAdmin.
But when I go to the CB control panel I see this error:
What could be a solution?Table 'nieuw.bu2rk_kunena_configuration' doesn't exist SQL=SELECT * FROM bu2rk_kunena_configuration WHERE id=1
Thanks,
L.
Mamp/localhost
Joomla 3.4.4
PHP 5.6.10
DB collatie utf8mb4_general_ci
Apache 2.2.20
safe mode = off
cache disabled
then install kunena again.
Which version a do you have from kunena and CB
CB version 2.0.11
Kunena version 4.0.5
I can't reproduce this issue.
Tomorrow I will compare the two Joomla's
