Important Kunena 4.0.3 installation error
11 years 3 months ago - 11 years 3 months ago #167435 by glente
Tried to install Kunena (fresh install). Got this message. Tried to install in Chrome and in IE (after advice from this post: www.kunena.org/forum/k-4-0-support-archi...upgrade-fails#165785 )
Any ideas?
Kunena Installation Failed!
Sorry, installation failed with following error:
Warning: DOMDocument::load(): I/O warning : failed to load external entity "/home/www/hematology.dk/administrator/KPATH_ADMIN/install/install.xml" in /home/www/hematology.dk/administrator/components/com_kunena/install/schema.php on line 281
Warning: Invalid argument supplied for foreach() in /home/www/hematology.dk/administrator/components/com_kunena/install/schema.php on line 422
Fatal error: Class 'KunenaRoute' not found in /home/www/hematology.dk/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 147
Last edit: 11 years 3 months ago by glente.
11 years 3 months ago #167441 by 810
11 years 3 months ago #167493 by glente
I have tried
1) go to extentions - plugins - check if system Kunena plugin is enabled
2) clear cache
3) try to install kunena
4) if not working, instal admintools
5) change database collation. to utf8_general_ci
6) try to install kunena again
Now the collation. is utf8_general_ci. When I try to install, I just get "ERR_EMPTY_RESPONSE"
I have tried IE and Chrome. No luck there...
Any more ideas?
11 years 3 months ago - 11 years 3 months ago #167496 by glente
I tried to install from tmp dir instead of from a zip. This was successful.
