Solved Updated plugins, crashed site
10 years 11 months ago #170931 by butchjax
I can't login, anywhere. And it says: ERROR: mod_kunenalogin: Kunena 3.0 (or later) is not installed on your system!
Yet it was installed yesterday before it all went kaput. I updated to 3.1.1.
10 years 11 months ago #170932 by butchjax
And I can't do anything because I can't login to the front or back end :-(
10 years 11 months ago #170936 by sozzled
butchjax wrote: I can't do anything because I can't login to the ... back end
Then this indicates that there's something more serious or sinister happening than merely the result of updating some "plugins". This suggests that your site is compromised—a euphemistic way of saying that your site has been hacked—and, perhaps, the best way to escape from your dilemma is to restore your site from the last backup taken before the problems began, accept that you may lose some information in the process, and then move forward.
Good luck.
10 years 11 months ago #170937 by butchjax
Ok. Thanks! I'm looking at joomla as well. 810 is assisting me right now and I'm incredibly grateful.
10 years 11 months ago #170938 by sozzled
As a matter of curiosity, what version of Joomla were you using before your site crashed?
10 years 11 months ago #170939 by butchjax
The latest, 3.4.5 I believe. And the latest of Kunena. We just had it all upgraded and had to fix a bunch of issues to make it all work well.
