Solved A "simplified" Kunena
Josh wrote: The resolution in those screen shots is quite low making it hard to know exactly what fields you want removed. I can provide a CSS mod to hide them, but I need to know exact which fields to hide.
Hi Josh i have reposted new images please check if they are clear enough.
Thanks in advance.
The file name might be something along the lines of template.css in a css folder of that template. Then to remove the user parameters go to: yoursite/administrator/index.php?option=com_config&view=component&component=com_users (yoursite is replaced by the url of your site). Set "Frontend User Parameters" to hide.
Thats issues:
Issue 2 sorted
Issue 3 sorted
Issue 4 sorted
Am still waiting for the other two issues.
Issue 1
Issue 5
To perfect it
Is there a way to choose or edit a field from IMAGE number 2? The county and city field have vanished as well and thats all i needed from that field. Can i just activate only those?
While still on the profile:
How can i get lock usernames and have users to log in using email and password am using joomla,kunena and social login?
Thanks for the help that you have offered so far i do appreciate.
Then insert the following into the CSS file to hide most of the fields and keep some:
Regarding the email issue, might I suggest checking out Authentication - EMail
As for issues 1 and 5: So you want Kunena completely hidden from guests? I'm a little confused by what you mean on #5 regarding "that menu".
Josh wrote: It was a little tricky considering Kunena does not provide classes for any of those fields. By using a pseudo class I was able to select the proper field (tables didn't play nice with me either). Anyways remove the following from your CSS file:
Code:/* Hides the Profile Information Tab */ #kprofile-edit dt:nth-child(2) { display: none; }
Code:/* Hides most social fields but keeps signature and location */ .kblock.keditprofile tr.krow2:nth-child(3) { display: block !important; } .kblock.keditprofile tr.krow1:last-child { display: block !important; } .kblock.keditprofile tr.krow1, .kblock.keditprofile tr.krow2 { display: none; }
That one worked fine although it reactivated the signature field instead of the personal text field, just noticed i had renamed personal text to city. For that matter i can leave the signature but can you please code for the personal text to show as well then from end it will show the current city. please Thanks
Many Thanks Josh
Josh wrote: Regarding the email issue, might I suggest checking out Authentication - EMail
That will help thanks.
Josh wrote: As for issues 1 and 5: So you want Kunena completely hidden from guests? I'm a little confused by what you mean on #5 regarding "that menu".
Yes i would like to hide kunena completely from guests but when i deny permission to guest and i happen to set a kunena menu as the default page. Visitors were getting an error. So i though i can give visitors access to kunena, set menu of a thread as default and then deny guest access to that thread. That way it was working fine but was showing that message.
What i was trying to archive is to have a site for registered members only but the landing page is a kunena topic.
But number 5 is no longer a priority.
Many Thanks Josh
