Solved Background of forum buttons wont display correctly
12 years 10 months ago #151790 by 9themestore
Can you provide me an account to check this issue? Please send me via email.
12 years 10 months ago #151816 by JamesCarter
I could not find your email, so I will just post the info here:
login: kunena
pw: kunena
Thanks again! :)
12 years 10 months ago #151820 by 9themestore
Hi James,
Open the template.css file of the current Joomla! template and add the bellow css code section to bottom this file.
/* Quick fix for Kunena button */ body #Kunena .kicon-button span { background-color: none; }
Regards,
12 years 10 months ago #151823 by JamesCarter
I did that, but it did not change anything. Maybe I have to wait before the changes take effect?
Btw, when I inspect the elements with firebug, i see a css rule saying:
background-color: inherit;
background-image: inherit;
background-repeat: no-repeat;
border: 0px none;
display: inline-block;
margin: 0px -5px;
If I then disable the very first one, the buttons are suddenly shown correctly on my page. Could that be the problem?
This css code lives in a file called kunena.forum-min.css .
12 years 10 months ago #151824 by 9themestore
You should not edit anything in the css files of the Kunena template. Because if you update new version for Kunena template you don't remember what you updated. If you want to override anything the Kunena forum you should write it in the Joomla! template. So you should update my code to the template.css file of the your current Joomla! template.
12 years 10 months ago #151864 by JamesCarter
As I said, I added it to the Joomla template but it does not seem to have an effect. :(
