Kunena 7.0.8 Released
Merged Best way to upgrade from K 2.0?
sozzled wrote: Of course that just my opinion; that's the way I have performed several hundred updates of Kunena. People can use any way they like.
That would not be just an opinion then, it is a "professional opinion." Thanks Sozzled and 9themestore, the upgrade was successful and without error.
I'll be sure to contribute another donation for another great version of Kunena "3.04." And 9themestore, I'll be clicking your ad to purchase a template from you soon enough.
True, K 3.0 is not compatible with many of the older modules or add-ons that were designed for K 2.0 in the sense that (a) there's no certainty that any or all of those older things will work with K 3.0 and (b) the team has not tested these older things with K 3.0.4. K 3.0 involved many internal structural changes that may prevent old software (or personalised, custom modifications that you may have made to the original K 2.0 source files) from interoperating nicely with K 3.0. In fact, because of these internal structural changes (and the need to make K 3.0 operable in J! 3.x) it is more likely that those old things will not work.Buldog wrote: But what means this:
Kunena 3.0 is not compatible with modules or plug-ins designed for previous versions and we recommend you disable all old Kunena extensions before installing or upgrading.
Because I do not know what specific modules, plugins or add-ons you are referring to, I can only respond to your question in a very general way. Which specific modules, plugins or add-ons are you referring to?
There should be no reason to suspect that "old" settings will not be retained. If we are only discussing Kunena, the configuration settings that you used before and the categories and topics and posts in those topics that exist in your K 2.0.4 forum, these things will be preserved. K 3.0.4 has some new configuration settings that did not exist in K 2.0.4 but there's no reason for you to believe that those new settings will affect the operation of your forum after you upgrade. If you have suspicions then the general advice is that you should test the upgrade on a copy of your original site to see what happens.Buldog wrote: How can I upgrade then the old settings and users?
As far as the "users" are concerned, "Kunena users" are Joomla users and the upgrade from K 2.0.4 to K 3.0.4 should not impact them. There are also forum tools to synchronise the Kunena users with the Joomla users and to recount the forum user statistics.
This should be treated as a separate issue and as a separate topic. I searched the forum for information about this error message but I could not find any information about it that I can suggest may help. Please start a separate topic on this subject with the title "Fatal error: Class 'KunenaForum' not found in\administrator\components\com_kunena\install\model.php on line 1363" and we will see what we can do to help you. Please also watch the video vimeo.com/69818669 and use the information in your new topic.Buldog wrote: I try a few things and get every time this error:
On behalf of the Kunena team, we thank you for your genorous donation.Shimei wrote: I'll be sure to contribute another donation for another great version of Kunena "3.04."
I forgot to tell that install with the link in joomla not work.
I download it from the home page en unzip it.
And i only install com_kunena_v3.0.4.zip.
That was the error.
I install the other things en de error was gone.
