Solved K 3.0.6 + J! 3.3.6: "Installation failed"
11 years 6 months ago #160187 by zevious
Checked that, and both the Kunena system plugin and the quickicon plugin are enabled after the initial install. The Joomla installer seems to be doing what it's supposed to do, actually. It's when Kunena tries to finish the install with its own installation handler that it never gets past that step. Perhaps it's an AJAX issue of some kind in the Kunena installer?
BTW:
/administrator/index.php?option=com_kunena&view=install&task=run&i2bbmjao
Is the file it's trying to run after the Joomla install finishes, and I don't know if that's the issue or what but it's the last file I see in the inspector. (the token after the ampersand changes after each reload). I'm not getting any Javascript errors or any errors at all showing in the Chrome inspector.
Should be pretty easy to replicate, as well, just download Joomla 3.3.6 and try to install Kunena on it.
11 years 6 months ago #160202 by 810
can you try this;
regards 810
11 years 6 months ago #160208 by zevious
Yes, that does the same installation failed thing as everything else. The Kunena part of the installer isn't completing on Joomla 3.3.6.
11 years 6 months ago #160209 by 810
is it a local site, or can you give me admin access to check some things
11 years 6 months ago #160213 by zevious
I can - how should I give you the information to log in?
11 years 6 months ago - 11 years 6 months ago #160215 by 810
jelle at kunena.com
Last edit: 11 years 6 months ago by 810.
Time to create page: 0.244 seconds
