Solved K 3.0.6 + J! 3.3.6: "Installation failed"
11 years 6 months ago #160220
by zevious
Replied by zevious on topic K 3.0.6 + J! 3.3.6: "Installation failed"
Great, sent.
11 years 6 months ago #160227
by 810
Replied by 810 on topic K 3.0.6 + J! 3.3.6: "Installation failed"
mhhh stange. we can try one thing.
Create a new website. + new database.
But this time name the database without the _ between names. Just named it like j33 or something.
11 years 6 months ago #160228
by 810
Mhhh it worked after changing Database Collation i think, or changing settings, then php cache..
I don't know what the fix was, but it works now again.
The following user(s) said Thank You: zevious
11 years 6 months ago - 11 years 6 months ago #160252
by zevious
Wow, that was it - the database coalition. I always set mine to utf8mb4 since that is the "true" multibyte variation, but I guess Kunena doesn't like that at all. When I changed the database coalition on my other site with the same issue, to plain utf8 coalition, it got past that first installation step and finished the install just fine.
Suggestion for future: Figure out some way to show an error message if it can't work with that for some reason
Thanks so much for your help!
Last edit: 11 years 6 months ago by zevious.
11 years 5 months ago #160351
by dc006
Replied by dc006 on topic K 3.0.6 + J! 3.3.6: "Installation failed"
Hi I would like to report the same issue. Kunena wont install on database with collation set to utf8mb4.
