Solved Installation fails with "Use of undefined constant KPATH_ADMIN"
12 years 11 months ago - 12 years 11 months ago #148736 by Prototyp 206
I tried to reinstall, but aborts now with an fatal error
Installation mit folgendem Fehler fehlgeschlagen:
Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /var/customers/webs/teeworlds/administrator/components/com_kunena/install/schema.php on line 12
Last edit: 12 years 11 months ago by sozzled. Reason: Call stack hidden to conserve screen real estate
12 years 11 months ago #148743 by xillibit
Check if check that System - Kunena Forum plugin has been turned on in your system. It's required to get Kunena to work.
Then when you have enabled it, go to Kunena backend the isntallation process will continue by itself.
12 years 11 months ago - 12 years 11 months ago #148792 by sozzled
Prototyp 206: Has your problem - this problem - been resolved?
12 years 11 months ago #148802 by Prototyp 206
Well System - Kunena Forum was disabled. Don't know why, but now it works
Time to create page: 0.230 seconds
